For several yrs Ive had an intermittent overheat problem. The only time its happened is when I start up the motor on the muffs in the driveway after it hasnt been run in a long time. After idling a few minutes, the warning horn would go off.
Never had an alarm while actually operating the boat on the water. Water pressure gauge shows good pressure.
Sometimes I tapped the thermostat housing with a hammer and metal rod, and it would go away. I figured I had a sticking thermostat, but since it only happened once in a while, I lived with it. Especially since changing the thermostats on this motor is quite difficult.
Well, I changed the thermostats today, and the problem still occurred...once.
I started the motor, the thermostats opened and hot water came out the exhaust ports above the anti-ventillation plate. But after about 5 minutes the tell-tale got real hot, and the alarm went off.
I restarted it about 10 minutes later and let it idle for 20 min+ and it didnt happen again, the telltale stayed cool too.
What gives, the impeller is only ~2 yrs old but has maybe 10 hrs on it. I have ingested mud and silt once or twice, but not sand. In any case, the water pressure is fine.
