  #1
Old July 4th, 2007, 11:42 AM
chbailey's Avatar
chbailey chbailey is offline
Send a message via AIM to chbailey
Default 97 evinrude appears to be only firing on one cylinder
I have a 97 Evirude motor that was having problems idling and seemed to be bogging down while running wot. I knew I was only getting about half the performance of the motor. I talked to a dealer and they suggested pulling one of the plug wires while running the motor. I pulled the top wire and the motor quit. I pulled the bottom wire and the motor kept running. I put some fuel in a glass jar and I don't see any water in it. I am getting a charge out of the second wire and I replaced the plugs. Same results. Anyone?
  #2
Old July 4th, 2007, 11:52 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 97 evinrude appears to be only firing on one cylinder
welcome to iboat, it's a 97 what. so you are saying, i think, you have spark on both cylinders, but it is not running on the bottom cylinder. in thats case if would check the compression on both cylinders. not know what motor you have thats as far as i will go.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 4th, 2007, 12:41 PM
chbailey's Avatar
It's a 97 Evinrude 2 stroke ESL. I reversed the timing from the power pack and swapped the plug wires so #2 was firing cylinder 1 and the motor still died. So my power pack works fine and cylinder #2 still does not fire. The cyclinder head looks clean. I don't see any pealing paint save the white paint on the bottom half of the head seems to be wearing off. But I would say that is from time and use and not over heating.
Looks like the cylinder head has never been off and a friend of mine suggested pulling the head and seeing if the gasket is shot. Seems logical that the gasket would be bad considering the motor is 10 years old. That would go hand in hand with compression issues.
  #4
Old July 4th, 2007, 12:45 PM
what horsepower is it. do a compression check. don't go pulling heads until you know you need to. if you don't do the right troubleshooting all you are doing is wasting time, and money on parts you don't need. a 10 year old motor is not even broking in good.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old July 4th, 2007, 12:50 PM
chbailey's Avatar
It's a 50 HP motor. I can get a compression test done in a couple of days. What are the chances it's a bad cylinder?
  #6
Old July 4th, 2007, 01:01 PM
now i have something to work with. the 50 has 2 carbs, it sounds like the bottom carb, is not letting fuel into the bottom cylinder. take some premixed gas in a spray bottle, remove the front of airsilencer, so you can see into the carbs. start the motor, and spray fuel in to the bottom carb. if the engine picks up that's your problem. the float needle in the carb is stuck. very simple fix. to remove the carb, and clean them.
a dead cylinder is not rare on a neglected 10 year old. if it's been run hot, or with a poor fuel oil mix, or run dry, for and extended period. due to a clogged carb.
__________________
FLORIDA GATORS
TEBOW Country
  #7
Old July 4th, 2007, 01:04 PM
chbailey's Avatar
The spark plug appears to be wet when I pull it out but I'll try your suggestion too.
  #8
Old July 4th, 2007, 01:26 PM
ok wait a minute.
" I reversed the timing from the power pack and swapped the plug wires so #2 was firing cylinder 1 and the motor still died. So my power pack works fine and cylinder #2 still does not fire"
are you saying that the coil on #2 did not fire. if thats the case you need a coil.
__________________
FLORIDA GATORS
TEBOW Country
  #9
Old July 4th, 2007, 01:42 PM
chbailey's Avatar
The coil on #2 was firing cylinder #1 but the coil going to #1 (which was #1) still would not fire #2. I'm saying either way, cylinder #2 would not fire even though it had #1's connected which was working. Also, cylinder #1 would fire with #2's coil.
  #10
Old July 4th, 2007, 02:00 PM
ok so the coil and the power pack are good. then it's either the carb, or compression. and you said the plug was wet. leads me to want a compression test on both cylinders.
__________________
FLORIDA GATORS
TEBOW Country
  #11
Old July 4th, 2007, 02:07 PM
chbailey's Avatar
That what was pretty much led me down the path of the pulling the head. I'll get the test done first before I go through that. Also, I was manually turning the head and it would be firm and a little difficult for the first turn and a little easier for the second and back to firm. So it pretty much seems like the second cylinder.
I'll get the compression test done and go from there.
Thanks for the help, I really appreciate it!!
  #12
Old July 4th, 2007, 02:17 PM
pay attention when you pull the head to see if the gasket has blow out marks.
__________________
FLORIDA GATORS
TEBOW Country
  #13
Old July 4th, 2007, 08:00 PM
chbailey's Avatar
No blow out marks that I can see. Gasket seems kind of gunky. Should I steel wool it to get it clean and put it back together and see if I get the compression needed? Or replace the gasket first and then put the head back on? Compression chambers look good and when manual turning the fly wheel the cylinders appear to be in normal operation.
  #14
Old July 4th, 2007, 09:12 PM
new gasket. then compression test. post results.
__________________
FLORIDA GATORS
TEBOW Country
  #15
Old July 5th, 2007, 02:12 AM
iwombat's Avatar
iwombat iwombat is offline
Has this motor ever been decarbed? Could have a set of stuck rings. Could also be a leaky exhaust gasket. Compression numbers should rule both out though.
  #16
Old July 11th, 2007, 05:56 PM
chbailey's Avatar
New gasket and compression ok. Dismantled carb and cleaned thoroughly and solved the problem. Doing a carb rebuild anyway.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 4 hp, top cylinder not firing milenine Johnson & Evinrude Outboards 1 June 2nd, 2007 06:43 PM
'79 Evinrude 35hp - Cylinder not firing...kill switch? Captain Caveman Johnson & Evinrude Outboards 6 March 27th, 2007 10:21 AM
Evinrude 115 v4 cylinder not firing pdowning Johnson & Evinrude Outboards 1 June 30th, 2005 10:55 AM
1 cylinder not firing 1998 Evinrude 200 darnak Johnson & Evinrude Outboards 8 March 20th, 2005 01:53 PM
1980 25 evinrude bottom cylinder not firing gamegetter Johnson & Evinrude Outboards 3 September 17th, 2003 07:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
