MadCityMike
- Jun 9, 2007
- 12
Previously have always owned Johnson outboard boats and just picked up a boat with an 85 3.0L 140hp Alpha One. It has a few issues I was hoping someone might be able help me out with.
1 - The quicksilver remote throttle only button doesn't disengage the gear selector cable, so there's no way to give it throttle without it being in gear. Is this a common issue for this vintage remote? Easy fix? I've removed the button but can't see anything so far as to why it doesn't work.
2 - Idle speed. It idle's really choppy so I bumped it up a couple hundred rpms so that it runs smoother and doesn't kill on me. I then found out that I couldn't shift from forward to neutral or reverse to neutral. It would just jump from forward to reverse or reverse to neutral. Is this working as designed? Is there something else I can adjust to allow for idle speed I want AND be able to shift? Sorry the tach doesn't work, so I can't give an exact rpm, but I bet it's around 700 - 800.
3 - When under power if I steer to the left or right I can hear noise coming from the sterndrive and can feel a lot of vibration. Do these use U-joints or CV joints, or something else for that matter? If U-joints, does that sound like what it could be?
4 - As far as manuals are concerned, I've seen posts not to get the clymer's and to get a different one. Which one should I get and where can I get it?
5 - The Trim/Tilt gauge doesn't seem to work and I was curious where I would find the sender for this gauge?
6 - What temp should the engine be at once warmed up? Do these run a thermostat like a car, or is there water always flowing through?
Sorry for all the questions and thanks for any help in advance!
Mike
Mike
