Popped the flywheel off my 66 Johnson 40 HP Electric Seahorse (actually, w/ what was left of the sheared flywheel, it came off just by lifting).
Further digging, removing the armature plate, there is a brass plate. Under that brass plate, is an aluminum plate w/ 4 threaded holes and a rectangular large slot/keway (this plate is what the armature plate itself threads to).
My aluminum plate is cracked at the bolt holes, and is in three pieces (this no doubt affects things...and hopefully that's where the diagnosing stops)...any idea which may have happened first (key breaking, or plate breaking)?
What is this piece called...and is it likely to be available through a dealer (or is it too uncommon to likely be stocked)?
I have a printed manual, and the schematic that shows what I think is a similar looking piece, is #89...but that's on a blowup w/ the block's components)...unfortunately, I don't have a second page w/ the complete part name listing...and on the schematic w/ the flywheel and armature plate components, there is nothing else shown on that page that correlates to this piece.
Any help would be appreciated...I know, I'll check the manual back out from the library ASAP (I just never thought the last Evinrude would stop letting me down...but now it looks like I may be hooked w/ two...and trying to keep them running).
