  #1
Old July 3rd, 2007, 04:38 PM
Wexfordboat Wexfordboat is offline
Unhappy 2002 Evinrude 115 Ficht starting problem
I am new to this forum and I would really appreciate a hand with this one if someone could take the time. Here goes:
Motor (2002 115 Evinrude Ficht) started and ran fine some weeks ago. Cut out, restarted after some time but was confined to computer-limited revs back to port. No obvious problem, nothing showing on dashboard warning lights or subsequently on Evinrude laptop diagnostics.
Now will only crank over (without starting) for a very short period until it shuts itself down. If the electric feed to the bottom port fuel injector is disconnected, the engine cranks for a slight bit longer before quitting and sounds like it might start if allowed to crank over for long enough.
Tests show just under battery voltage (11.5v) with ignition on and around 22v under cranking - normal. 40v circuit tested and ok.
All fuses ok. All HT and plugs tested and ok. Fuel injectors tested and ok.
Any ideas why this motor will not even crank over properly let alone start?
Thanks for your time.
  #2
Old July 3rd, 2007, 05:14 PM
Palssonater's Avatar
Palssonater Palssonater is offline
Default Re: 2002 Evinrude 115 Ficht starting problem
11.5 volts on your battery is too low. A properly charged batter should read greater than 12volts and possibly over 13 volts.
Not sure where you are from, but has the battery been in any cold weather? Any possibility of it getting frozen? How do you store your battery when not in use. It is essential that you do not store it on bare concrete (like the garage floor). Place it on a block of wood or insulation foam.
If you think the battery is good, try throwing a trickle charger on it over night. It will read over 12v's to begin with after charging, but may degrade fast.
Not sure how essential the battery is to this particular motor, but I know on ATV's with EFI a bad voltage regulator or battery sends them into "limp mode" for safety.
Not sure if this is it, but a place to start nonetheless...
  #3
Old July 3rd, 2007, 05:55 PM
Wow, that was fast, thanks Palssonater.
The voltage in the injector circuit should read approx 1v less than battery, unless cranking (c. 22v) or running (c. 40v), this is normal. Battery is ok but has been bypassed with an external battery just in case. This is one of those cases where we think that all obvious (and some not so obvious) solutions have been explored. It has gone past frustration into obsession!!!!
I'm in Ireland, and your question about over-wintering batteries is a good one for our climate but all seems okay in that department.
Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2002 90 hp evinrude ficht Chris Hiscock Johnson & Evinrude Outboards 1 April 29th, 2007 09:26 PM
2002 Evinrude Ficht 250's ibillfish Johnson & Evinrude Outboards 2 April 17th, 2007 08:18 AM
2002 Ficht Ram 90HK - Strange tilt problem satnerd Johnson & Evinrude Outboards 5 August 23rd, 2006 01:57 PM
2002 150 hp evinrude ficht jebb Johnson & Evinrude Outboards 4 May 21st, 2005 01:13 PM
2002 Evinrude 225 FICHT Ram Capt. Lou Johnson & Evinrude Outboards 4 April 3rd, 2005 07:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
