1956 Evinrude 15hp Impeller Change
Status
Not open for further replies.
cary00silve
I have a 1956 evinrude that I just got running and sometimes it pumps water, other times it doesn't. I am planning on pulling the impeller out and throwing in a new one. I have had some people tell me that I must remove the powerhead to remove the lower unit. Is this true? If so, what are the procedures for replacing the impeller? Thanks...
tashasdaddy
Re: 1956 Evinrude 15hp Impeller Change
it should havg 1"x2" plate 1/2 way up on the leg of the motor. this is access to the shift linkage connector. remove plate, and loosen bottom screw, do not remove. then after removing the bolt to the lower unit it should just drop out. this linkage has to go back together the same as it came out. be sure to line up water pipe. may have to remove plugs, and rotate flywheel to get splines to line up.
cary00silve
Well, I got the impeller out and it needs replacement. However, there is another problem. The impeller key is rusted into the driveshaft and it broke off flush with the surface. I am going to try to drill it out and see if I can get all of the material out of there. Any other thoughts on what to do?
tashasdaddy
dremel works very well.
samo_ott
ohoh... be careful here... the older driveshafts are hard to come by... I would try a dremel or other rotary tool.
tashasdaddy
hold everything. the 15 has a pin not a key. it's like a 1/8 inch pin. that engages the impeller.
cary00silve
Well, I just got it out. It needed to be drilled out because the pin was still broken flush with the surface. I was able to put it in an end mill and drill it out. Just out of curiousity, why wouldn't a regular key work just as well as the pin?
F_R
'Cause it is drilled for a pin. Drilling is cheaper than milling. Pins are cheaper than keys. Bean counters, you know. Save 10 cents per motor times 100,000 motors, lessee what's that? Ten thousand dollars?
cary00silve
Sorry, it was miscommunication on my part. By key, I just meant that it had the flat vertical part that locks into the groove on the impeller. The correct term is pin, I just used key because in my mind a pin is just a straight 1/8" rod. I drilled the hole back out to 1/8, and now the pin fits in fine.
bluesboater
Can you please clarify a few things for me. you said that you remove the plate that is covering the shift linkage connector. than you said to loosen bottom screw. The bottom screw of what ? Thanks
There is a connecter there.-----You MUST remove one of the screws in the connecter.
bluesboater
Can you please clarify a few things for me. you said that you remove the plate that is covering the shift linkage connector. than you said to loosen bottom screw. The bottom screw of what ? next you siad "then after removing the bolt to the lower unit it should just drop out". Is "it" the impeller? Thanks
MODERATOR EDIT: Please review the forum rule about posting to old threads.
Crosbyman
post is 18 years old...... best to start a new one !! see #60 behind the plate
Status
