my 1973 18' sea ray has a 1973 merc 850 on it currently, but doesn't move it along as fast as i'd like. so i've been keeping my eyes open locally for a 1350 or 1500 straight 6 from the same era. well i found a 1974 1500 with power trim that is complete with controls and is currently on a 16' glastron. the boat is shot. really no value to it. the current owner got it from an estate sale and knows nothing about it other than it spun over when he hooked up a battery. it was last registered in 2003.
so before checking this motor out, i wanted to get some opinions on what to look for. what should the compression in each cylinder be? should i hold the carbs wide open when checking? i'm bringing my ears and will attempt to start it after checking the compression. the lower end took a pretty good hit and the bottom fin is shot. will the lower unit from my 850 fit this motor? i've read here that it would, but doesn't that also depend on whether or not it is a short or long shaft? and how do i tell short vs long shaft? where should i measure to and from and what should the measurements be?
any other things to look out for? are there any peculiar attributes about a '74 1500 that would make me want to stay away from this model? also, if everything checks out, whats a fair price to pay for it?
any info is greatly appreciated. thanks.
