  #1
Old July 3rd, 2007, 12:27 PM
FastOrange FastOrange is offline
Default Riveted aluminum Starcraft leaking bad
It takes on about 5 gallons a day. Its leaking around the center of the hall. Does anyone know the best way to tackle this problem?
  #2
Old July 3rd, 2007, 12:49 PM
reelfishin reelfishin is offline
Default Re: Riveted aluminum Starcraft leaking bad
Check for loose or missing rivets, replace any that are missing, tighten those that are loose. Coat the inner hull with Gluvit and paint.
  #3
Old July 3rd, 2007, 02:23 PM
iwombat's Avatar
iwombat iwombat is offline
Just how big a boat are we talking here?
5 gal over the course of an entire day isn't all that bad for an old riveted tinny, say 16' or better. The key is to find out where it's actually leaking. Fill the hull with water and watch for drips on the outside. Circle them with a sharpie.
My '77 18' SS takes on about that much over 24 hours of motoring about, but almost none at the dock. Turns out, a lot of that is leaking in from the splashwell joints. (Yet another thing to fix). Find out the cause first, before you go fixing up non-problems.
A good gluvit-ing is never a bad idea though.
  #4
Old July 4th, 2007, 12:58 PM
we filled it up with water and it was leaking out in the center of the haul, under the fuel tank. There is a dent at that location too. It's a 17 footer
  #5
Old July 4th, 2007, 01:13 PM
Steve Mahler Steve Mahler is offline
I have a 15 foot closed bow starcraft with a dent in the center, and a similar leak. I have had a really hard time getting it completely water tight. Since my issue (and maybe yours) isnt so much loose rivets as much as a crease from the dent, I think the only real solution is welding - which is expensive on an alum boat. I did gluvit, and a few other semi-successful leak solutions, and it slowed the leak a lot - but not to where I could dock the boat for the summer....so it is for sale, fiberglass for me from now on.
  #6
Old July 4th, 2007, 01:26 PM
iwombat's Avatar
If you can get to the backside, you can pound out those dents. Use closed end blind rivets (drill out the old ones from the outside) and gluvit it shut. Works great. I pounded out some pretty substantial dents on mine right along the keel.
  #7
Old July 4th, 2007, 01:29 PM
thinksun thinksun is offline
I was given a 14' Starcraft from a guy because he couldn't fix the leaks. Access to rivets was easy but may not be for you're boat. The fix was easy and 8 years later it is still dry.
I used a stainless wire brush in drill on leaking rivets to remove oxidation. I bought an epoxy repair stick (green) which you heat/burn with a propane torch. The stick starts to drip like a candle and I let it cover leaky rivets. The finish is smooth and neat.
If I can find product name I will post.
  #8
Old July 4th, 2007, 03:06 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Quote:
BAD IDEA! FastOrange stated "we filled it up with water and it was leaking out in the center of the haul, under the fuel tank. There is a dent at that location too. It's a 17 footer....."
If you go as far to remove the fuel tank then go for it.... but once you are in that deep you can repair the rivets and use gluvit.
Basically there is no real quick fix except for tightening and replacing the rivets.... coat your new rivits with 3m5200 before you pop them.
Maybe time consuming but it can be fixed.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum "riveted" boat problem NathanY Boat Topics and Questions (not engine topics) 5 April 22nd, 2009 05:47 PM
aluminum starcraft leaking critter34 Boat Topics and Questions (not engine topics) 3 July 20th, 2006 10:37 AM
aluminum riveted boat ? wayne h Boat Topics and Questions (not engine topics) 52 June 16th, 2005 01:24 PM
Starcraft Aluminum Boats Seagull6 Boat Topics and Questions (not engine topics) 1 April 9th, 2003 10:32 PM
Starcraft Aluminum Boats Seagull6 Starcraft Boats 1 April 9th, 2003 10:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
