Lucrestyle
- May 25, 2007
- 98
I know this has been covered a million times on here, and i did the search but sometimes problems can be unique.
boat- 1989 Larson Senza 165
engine- 1993 Rude 120hp
Problem- tach never worked properly before on previous engine 90hp... current condition - itermitten tach now (works but fails at WOT)
I checked all wires according to teleflex, it was set to 6.
the tach will work up to about 3 / 3500 grand - then at WOT it will fail.
if i slow it down the tach picks back up.
the tach does zero out when i turn the key to on position.
any idea's, what should i check first... does this sound like a ground problem to you, i have three black ground wires leading off the tach.
should i sand down / scuff terminals to get better conductivity?
should i follow ground wires to check actual grounds?
does this sounds more like a rectifier problem?
any help would be awesome! thanks fellow boaters!
