reeldutch
- Feb 2, 2004
- 1,340
i rebuild a 1988 v4 looper with a 87 block bored to std 88 big bore.
replaced tstat system with the 1993 suffix s tstat system and works flawlessly. at idle 135 to 145
at 3000 i can feel it cooling down.
it idles 650 rpm in gear.
out of gear 800/900 rpm.
coldstart
when i start the motor it will idle for 2/3 minutes at 1000 rpm till quickstart deactivates.
only in these 3 minutes the motor coughs a few times.
after quickstart deactivates no more coughing.
i checked the timing and it idles at 8*atdc.
should i be concerned or do they just start up rough?
the rest of the day it will not cough.
i have vro oil side plugged and runn double oil at this time.
i did not have the motor wide open yet i only had it at 5500 rpm to check the full advanced timing.
18*btdc
it seems that i have some more rpms left.
the motor is on a 1974 mako 20' with a stainles wheel 13 3/8 X 17
the motor is on a bracket wit a setback of 4" and the anti cavitation plate is about 2" above the keel.
i had the same setup with my crosflow 110hp and i got 5600rpm out of it with the same prop when the bay was flat as glass.
i think the 140 looper will get 6000 out of it.
should i look into a 19" pitch ?
reeldutch
coldstart
18*btdc
reeldutch
