Re: HELP...is it the coil?
ok let's do some trouble shooting before we start buying 4 new coils. 1st check the compression on all cylinders, should be over 100 psi, and with 10% of each other. take it out, run it till it acts up, remove the cowl, and touch the engine block just above the the cylinder heads, you should be able to hold you finger there for 2-3 seconds without it becoming extremely uncomfortable. now take one spark plug wire off and put so it won't ground, try taking off. then put it on and do the next onetill you have done the all. if there is a change note which one, that may be the culpret. if it is the same on all plugs, you can rule out the coils, and power pack. now going back if the one that had the change, carefully noting where all the wires go, completely swap coils with another cylinder. if the problems moves with the coil, the coil is bad. if not it's time to test the power pack. do this and get back with us. don't throw parts at it, it doesn't need. it will also teach him how to troubleshoot a problem.
