Re: How do I get to wires beneath bow light?
If the wires are in a channel, conduit, or wire-tie loops, you should be able to tie a cord to the bow light end and pull the wire to the switch or fuse panel. Color code should indicate which ones to tug on. Use the to cord to pull new wire and make connections.
