cajun66
- Feb 17, 2006
- 99
The motor sat up fpr a while and then wouldn't start. I cleaned the carb, changed the points, changed the fuel pump, and changed the water pump. After all that it would crank (sometimes) but die after a few seconds. I let it sit a year longer. This time, I changed the fuel pump (again) and completely rebuilt the carb with all new innards. Exact same symptoms. Will sometimes crank and will only run several seconds then die.
Any ideas?
Any ideas?
