  #1
Old July 1st, 2007, 12:59 PM
Campnc Campnc is offline
Post ***Prop Question?**(new boat owner)
I have a 3.0 OMC on a 87 Bayliner. The boat came with this totally worn and busted prop on it with no numbers at all and also one in the boat that looks different with the numbers 13 1/4 X R17. What kinds of props can I use on this type of outdrive? Is there just one size I can use or what?
  #2
Old July 1st, 2007, 03:04 PM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: ***Prop Question?**(new boat owner)
You have a Cobra drive, so you need an OMC compatible prop. Many brands these days are adaptable to multiple manufacturers. You just need the right hardware kit. Click on the OMC Cobra Props link above.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old July 1st, 2007, 03:41 PM
How about the pitch? Do I get to choose and how do I know what I need?
  #4
Old July 1st, 2007, 04:03 PM
Silvertip Silvertip is offline
There are two critical dimensions for a prop. Diameter (the size of the circle it forms) and pitch (the theoretical distance the boat moves with each revolution of the prop). A 17P prop theoretically move the boat 17 inch with each revolution. But since the prop operates in water, that is only theoretical and therefore there is slippage to contend with. Diameter is important because a prop that's too big around will hit the trim tab or the antiventilation plate. The hub is also important (the engine side of it) as it must match your outdrive. Click on the link below which is right here on iBoats. Enter you year, model and HP and you will be given a list of props. You would probably pick one from the middle of the list, unless someone comes by that has the same boat, same drive, same engine, and same year and oprates with the same load you do. Ideally you want to end up with a prop that when you run the boat wide open, the engine operates at or very near the maximum recommended wide open throttle rpm (4400-4800 rpm) for your engine. I don't think the 13-3/4 inch prop you have is correct for that boat.
http://www.boat-props.com/propellers...****=046505787
  #5
Old July 1st, 2007, 09:44 PM
kwikrnu kwikrnu is offline
I'm not a prop expert, but I did buy a boat almost 2 weeks ago. This came out of my omc book.
__________________
http://forums.iboats.com/image.php?type=sigpic&userid=96458&dateline=118507  5162
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop Question(New boat owner) Campnc Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 30th, 2007 07:34 PM
New boat owner has Overheating question Knot Waiting Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 October 4th, 2006 07:13 AM
Old Boat... New Owner... VRO Question brettagostini Johnson & Evinrude Outboards 6 July 15th, 2003 12:22 PM
New Boat Owner-simple Gas question darkalley Force & Chrysler Outboards 2 May 22nd, 2002 11:48 AM
newbie boat owner intro and question litlsea Mercury & Mariner Outboards 1 August 22nd, 2000 08:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
