MASTER Brian
- Mar 26, 2006
- 738
My '86 E-XP150 has been pretty hard to keep at an idle speed. The RPM's seem like they might be just a tad low, maybe 800rpms +/-. I know I've seen where it should be, but I don't recall.
The boat generally starts easily, but if I leave it idling long, it dies. This past weekend, the boat started up, then in the time I went to unhook from the trailer until the time, I came back to pull off, it had died. It was extremely tough to start after that. It might fire, but when I'd go to shift, it'd die out.
When it finally starts, it runs great. It even seems to idle better when it's warm and after it's been running a while. I shut the boat off several times during the last outing and it never was as tough to start as it was when I was trying to get it off of the trailer. I'm not sure if that was because I ran that fuel tank down fairly low the time before or if something else was the culpret. I fueled up prior to this trip to the lake. I swicthed tanks and it did start easier, but both tanks were left in the same state of nearly empty after last outing. Again, both were topped off, before this outing.
I had rebuilt the entire P.H. last year and it was running great. L.U. then went to the shop because of a shifting issue. They rebuilt L.U. and linked and synced the PH. I just got past the 10hour mark on the L.U. about 2-3 hours ago. I have called the shop, they just said bring it in and leave it. They are about 14 days behind right now.
I don't recall the idleing issue last year, but that was 8-9 months ago. I plan on pulling the plugs and cleaning/replacing, but I'm curious if that would be the problem. Early in the season, I thought it was the colder water, which was about 60*. The water is currently 70* and it's still acting the same if not worse.
Is it possible my choke is going bad or what would you check? I thought about just turning up the idle, but don't want to screw anything up.
Sorry, for all the info, but I want to provide as much info as possible. Should I let the shop figure it out, since they linked and synced it. Should I clean the plugs and try again. What about turning up the idle speed screw?
