Biggwaukegan
- May 23, 2007
- 3
Ok here it is. 1960 MFG niagara with a 1960 40hp Johnson SuperSeahorse. As normal for older boats it needs a little work. The motor worked fine when i took it out for the first test run. Gel coat needs a good scrubbing and polishing. No carpet so I need to do that as well, any tips on cheap boat carpet would be great. All of the wiring is working. Could use hull paint, and new windshield. Seats are brand new 4 swivels. Not a bad deal with boat motor and trailor for the 350. Trailor is dam near perfect. Any tips on restoring this bad boy would really help. Mainly the carpet and windshield. Gauges would be a plus but the old ones work. Want to use this boat for fishing and tubing. Thanks
