Re: QUESTION ON FLY-WHEEL NUT FOR 1990 Evinrude 30 hp WHAT TORQUE SETTING?
well i am not sure of the torque setting on that motor is but they are usually around 100ft pnds if you have the book for the motor it should be in there,as for tightening it up is there a timing mark braket on the back of the motor in witch you can have a buddy hold a screwdriver between the bracket and the teeth of the flyweel wile you torque it?
__________________
69 johnson 115, on a 69 searay aka shark bait!
