  #1
Old June 30th, 2007, 05:34 PM
compfast compfast is offline
Question replacing transom on pontoon
I'm replacing the transom on pontoon, it looks pretty easy. ................
I was wondering should I use Marine plywood or preasure treated?...andwhat kind of water seal should I use?.........
And I was wondering if the 3 peices of wood sandwiched together (so that the transom is thick enough) would trap water, and is there another way to make the transom with something that's a solid piece?
Thanks in advance
  #2
Old June 30th, 2007, 06:34 PM
CATransplant's Avatar
CATransplant CATransplant is offline
Default Re: replacing transom on pontoon
Regular ACX plywood is just fine. Make up the transom out of three thicknesses. Just glue 'em together with Gorilla Glue, clamping them overnight.
Then, give it all a good coat of oil-based paint, liberally applied to all surfaces, especially the edges. I use regular old Rustoleum, applied with a brush. It seems to hold up well, even on wood.
Why? Well, it's an item you're going to have to replace from time to time, whatever material you use. Why spend more?
Others may have other ideas.
  #3
Old June 30th, 2007, 06:37 PM
Bob_VT's Avatar
Bob_VT Bob_VT is online now
You can also shoot small stainless steel screws in to clamp the plywood and gorilla glue..... just leave the screws in there.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #4
Old July 1st, 2007, 08:54 AM
Thanks for the help guys .......................This forum is awesome!
__________________
1970 Kiekhaefer Mercury - 650 4cyl 65 hp
Thunderbolt ignition
  #5
Old July 1st, 2007, 10:52 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
total agreement.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #6
Old July 1st, 2007, 01:31 PM
Could you guys tell what type of clamp (or clamps) I need? I'm thinking Home depot will have them?
__________________
  #7
Old July 1st, 2007, 01:51 PM
would use around 8 large 'C' clamps, that you screw down one each corner, and one in middle each side.
__________________
FLORIDA GATORS
TEBOW Country
  #8
Old July 1st, 2007, 01:54 PM
j442w30's Avatar
j442w30 j442w30 is offline
Like Bob said, you could screw it together with stainless steel or deck screws and they will clamp the wood together while the glue dries. Just leave them in after the glue has cured and it will be plenty strong. It might just be me but it looks like your steering cable is a little worn out if the covering is cracked like it looked in the pictures.
  #9
Old July 1st, 2007, 02:44 PM
Thanks, ......I didn't realize the screws would clamp it by them selves, I thought they were in addition to the clamps
Yea the steering is shot, it's very stiff.........I ordered all new steering componets .they should be here monday....got a new console too
Thanks again
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pontoon motor support (transom) bherron Boat Restoration and Building 2 January 25th, 2007 09:21 PM
Replacing transom from outside oldtwainer Boat Restoration and Building 19 December 10th, 2005 04:32 AM
Adding transom bracket to 24' pontoon boat dhazlett Non-Repair Outboard Discussions 3 May 9th, 2004 05:35 AM
correct height of motor/transom pontoon? slake Non-Repair Outboard Discussions 0 June 15th, 2003 05:38 PM
Replacing Transom Saperry Boat Topics and Questions (not engine topics) 26 May 30th, 2002 09:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
