I bought a Mercury 7.5 h.p. outboard as is and just got it going. I have two potential problems. The first is that I can only get the thing started if I blow a bit of starter fluid into the carb. Other wise I crank and Crank and nothing. What could be the problem? The second more serious potential problem is that when I got it going, within a few seconds the cooling water stream was strong, but then it began to sputter and then turn to steam. I turned the motor off immediately. Can anyone tell me whether this steam is normal and if not whether its likely the water pump or the thermostat or something else? The weep pipe is clear. Is the inlet above the propeller? I cleaned that out as well. ANy help would be appreciated.
