  #1
Old June 28th, 2007, 04:40 PM
cwaff cwaff is offline
Default Late 80's Evinrude 225 power tilt/trim
I have twin late 80's (1987?) Evinrude 225's on a 25' whaler, but recently the port engine trim/tilt began to fail (didnt work, then worked, then didnt) and finally stopped completely in the 90% down position. This is good because I can still drive the boat, but pulling it out will be a trick. Also Lake Erie W. basin is very shallow and solid rock so the tilt was real handy anchoring near shore.
Got into it and there does not appear to be any fuses for the t/t motor specifically at the engine or in the bilge, are there? Both solenoids click when up or down button is hit, but no action, and all connections on them look good. Could it be I am low on battery (doesnt work when running), have 2 bad solenoids (it doesnt go up or down), a bad motor, not enough fluid, or something else?
Any ideas or ways to test are appreciated. Boating season is in full swing and there are fish to catch!-
Thx
Cwaffen@netlink.net
  #2
Old June 28th, 2007, 04:42 PM
Default Re: Late 80's Evinrude 225 power tilt/trim
Also - is there any manual way to get this engine up? I forgot to mention that i am at dock in the water!
Thanks!
  #3
Old June 28th, 2007, 05:19 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
On the starboard transom bracket, there is a hole near the bottom portion of it. Inside that hole is a manual release valve. Turn that valve two (2) turns out (no more than two turns)! that will allow you to lift or lower the engine. However, it will lower only to the trim rams and no further.
Trace the wires from the PTT electric motor to whatever connector exists and disconnect it. Now, using jumper wires, apply voltage directly to the electric motor wires. Did the electric motor run or did it spark wildly like a bad short exists?
Is that electric motor a 3 wire motor or a 2 wire motor? If a 3 wire motor, the black wire is of course the ground wire and the other two wires (green wire, blue wire) would be the up/down leads.
If a 2 wire motor, that would be a dual polarity motor, meaning that the positive battery wire would connect to one wire and the other battery wire would connect to the other wire..... this would make the electric motor run in one direction, and reversing the wires would make it run in the opposite direction.
Does that unit actually have two solenoids as one thinks of solenoids, OR does it actually have two small relays with a small black plastic rectangular box?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
80's Evinrude 150 Trim/Tilt wiring diagram puddingskin Johnson & Evinrude Outboards 4 July 30th, 2008 06:47 PM
Identifying late 80's Evinrude model # merc20 Johnson & Evinrude Outboards 3 August 9th, 2006 02:50 PM
Late 80's Evinrude Rebuild abrown Johnson & Evinrude Outboards 3 June 28th, 2006 10:37 PM
power trim/tilt system query early 80's stuart0 Mercury & Mariner Outboards 1 July 26th, 2004 12:19 PM
Late 80's Evinrude 28SPL No start Cairus Johnson & Evinrude Outboards 2 May 20th, 2004 07:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
