Re: Yamaha 150 Vmax Motor overheating
You may want to start with thermostats. One on each side. I go by the tourque specs when tightenting the cover bolts. Don't forget new gaskets.
The pressure relief valve has been redesigned by Yamaha. Do you have one of those? It probably is not causing your overheat, but it's a cheap part.
