Trim Switch
poolshark38759
i have a Tracker Pro17 with a 40hp.
?1 the trim switch on the shifter is not working properly.. it will trim the motor up but not down.. the bow and motor switches will trim the motor up and down.. the problem in the shifter switch or connection somewhere??
?2 the tach is not working either.. where do i start on locating the problem here..
this is also posted on the Johnson/Evinrude board
dimock44
Re: Trim Switch
Late reply!! I had the same problem it's the switch $45.00 is cheapest so far from Evinrude what motor do you have
