Water hose gone!!
Apollo
I have a problem with my 1973 mercruiser stern drive. I started it up this spring and my motor over heated. Looking into the problem I discovered that the water hose that takes the water from a fitting on the bell housing to a fitting on the gimbal housing, has part of it missing. It doesnt seem that I can get to the clamps to remove the hose and replace it without pulling the whole lower unit away from the bell housing. I hope I can do it myself as I cannot afford to take it someplace, unless absolutly nessessary. Can somebody please help me in solving this matter, I want to get it on the lake!
Re: Water hose gone!!
You're absolutely Right,......
While you have the Bellhousing Off,........ You should change out All the Rubber Parts in there,......
If the Hose is Rotten,... The Bellows won't be far behind.........
Apollo
Thanks for the help. Bond-o, do you know perhaps how much this would cost for a shop to do it?
