Mano del Sol
- Jun 1, 2007
- 56
I have been lurking here for a while and I have gotten a lot of good info from doing searches. This is a great site!
My stepfather gave me an old 12' starcraft boat and trailer a few years ago and I am now getting around to fixing things up a bit. The motor has always "ran good" but I know that it has had NO maintenance (except for a new set of plugs) in at least 10 years. Before that I can't be sure.
So I decided to work it over. I got a Seloc manual and I cleaned the carb and replaced the float, replaced all the fuel lines and a put in a new impeller. I have new points and condensers that have yet to be installed.
Now, I have several questions:
#1 - I checked the compression as is and I got 77 and 80 or so psi. Apparently I should have run it and decarbed before I can get a reliable reading? Is that right? Plus, I have read here that it should be 90+ but the difference between cylinders is more important, which begs the question: how low can the compression get before I consider ripping into the powerhead?
#2 - I took the flywheel off to install the points and condensers and I see that the coils are cracked. (new ones are on the way) So when I go to install them and push the wire into the coil, should I clean or trim the end of the wire first for better contact? Or should I just replace the plug wires?
#3 - I don't know how old the prop is, (it's the same color as the motor, could it be OEM?) but overall it looks pretty decent but it fits a "little" loose on the shaft. I measured the prop and shaft and there is only about .010" difference. How loose is too loose? I can definitely get wiggle out of it. I asked FOUR different buddies of mine and I got FOUR DIFFERENT answers. I don't really want to spend $70 on a new prop just to find out that the old was was really OK.
#4 - When my stepfather bought the boat he was told that the motor runs good, never had any trouble but it would never plane out that boat. So he put a stingray on it which did cure the problem, but that seems like a band-aid to me. Should this motor (if it is running correctly) be able to plane out a 12' aluminum semi-vee rowboat?
Thanks in advance.
Thanks in advance.
