  #1
Old June 27th, 2007, 11:34 PM
ET ET is offline
Default 73 Evinrude Dead Cylinder
I have a 1973 65hp evinrude triumph motor and cyl # 3 won't fire. I've changed the sparkplug, coil, powerpack, and stator. The cylinder has compression of a little over 100. Cyl #1 and 2 fire just fine. If I pull the #3 plug out while running there is no change, which isn't the case with the other two cylinders. I can't figure this out and I'm out of guesses of what it could be so i'm bringing my issue to the fine panel of experts. What could be wrong, and what should I test next? Also, could it be a something with the carb. Thanks for your help
ET
  #2
Old June 27th, 2007, 11:40 PM
The-Machinist's Avatar
The-Machinist The-Machinist is offline
Default Re: 73 Evinrude Dead Cylinder
What is the compression on the other cyls?
__________________
"We are what we repeatedly do. Excellence is therefore not an act but a habit."
___ Aristotle
For some people there's therapy, the rest of us have boats
  #3
Old June 28th, 2007, 06:30 PM
ET ET is offline
They were all right at 100
  #4
Old June 28th, 2007, 10:32 PM
offshore100 offshore100 is offline
Quote:
Originally Posted by ET View Post
could it be a something with the carb. ET
Well, since it sounds like you've done all you could do re. spark, maybe carb#3 is the problem.
What does the plug look like? Wet or dry?
  #5
Old June 28th, 2007, 10:43 PM
BoatBuoy BoatBuoy is offline
ET
Do you mean that you can't get spark on cyl # 3, or that it's just not participating in the running?
  #6
Old June 28th, 2007, 10:46 PM
If I pull the #3 plug out while running there is no change, which isn't the case with the other two cylinders. ET
Certainly, check to make sure you have a spark in #3 plug. You don't have to be running to do that.
  #7
Old June 29th, 2007, 12:23 AM
jtexas's Avatar
jtexas jtexas is offline
The trick is to narrow the problem down *before* spending any money on parts.
remove #3 spark plug, reattach it to boot, hold it against the engine block while somebody cranks the engine. use an insulated tool to avoid electroshock therapy. if you see a sharp blue spark, then rebuild your carburetors.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
  #8
Old June 29th, 2007, 05:13 PM
ET ET is offline
There is no spark on #3 and I'm pretty sure the plug is wet, I'll pull it out again today when I get home and post an update
  #9
Old June 29th, 2007, 05:40 PM
mikesea mikesea is online now
if you getting spark,fuel and compression,its possible your getting water into the cyl.via the exhust.the plates on the port side might be leaking water,when you remove the plug can you notice droplets of water,is the plug showing a rust color,.if you are getting spark,you can remove the carb cover,take some pre mixed fuel and spray it down the carb throat,if it fires ,you know you have a fuel prob,I would then suspect the carb,but,you could have a reed prob too,.check for spark first,if yes,try the throat trick,another thing you can do to check for water,carefully though,run the engine with the non firig plug out,put a piece of metal or glass close enough to the hole to see if water is appearing,but know that fuel may be present too,and has a good chance of firing if the dangling plug wire lites it off.just a couple old tricks,be careful
  #10
Old June 30th, 2007, 12:36 AM
ET ET is offline
I appreciate the help, i'll try all that out tomorrow
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
dead cylinder JV1964 Mercury & Mariner Outboards 3 September 28th, 2006 04:49 PM
Dead Cylinder - Evinrude 48 HP SPL - HELP! papakevin Johnson & Evinrude Outboards 8 April 21st, 2005 07:14 PM
Evinrude top cylinder dead packfan1967 Johnson & Evinrude Outboards 5 July 2nd, 2003 10:14 PM
Evinrude 3 hp 1947 ? 1 cylinder dead-intake crankshaft valve? moonlight Johnson & Evinrude Outboards 4 August 23rd, 2002 07:40 AM
dead cylinder hudgeons Johnson & Evinrude Outboards 1 July 8th, 2002 01:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
