  #1
Old June 27th, 2007, 10:46 AM
mchsprky mchsprky is offline
Default 1959 evinrude lark 35 hp cooling question
Hello I have a 59 evinrude lark 35 hp, In neutral i get a good spray of water out the exaust port even when reved really high,but the problem is when i shift into foward it still sprays till mid to wot then it stops if you put your hand over exhaust port fills like it is sucking, I have replaced the impeller the thermastat blew air through nothing is fixing the problem any ideas where the water might being stop from or if water is suppose to come out at wot
  #2
Old June 27th, 2007, 11:06 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1959 evinrude lark 35 hp cooling question
what are you running it in.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old June 27th, 2007, 11:14 AM
I'm running on the lake on guy throttling while i'm looking at motor
  #4
Old June 27th, 2007, 12:14 PM
F_R F_R is offline
So, are you just concerned about what's blowing out there, or is it actually getting hot at higher speeds?
Only a partial amount of the total water is discharged out that hole. Most of it goes out with the underwater exhaust. At higher speeds, the underwater exhaust is more or less scavenged, so the water just runs out down below instead of a lot coming out the upper blowhole.
If it was actually not circulating at high speeds it would overheat in a heartbeat.
  #5
Old June 27th, 2007, 12:19 PM
CATransplant's Avatar
CATransplant CATransplant is offline
That's perfectly normal behavior for that engine. Once you're under way, all the exhaust goes out the underwater outlet.
  #6
Old June 27th, 2007, 12:26 PM
larky's Avatar
larky larky is offline
I have the exact same engine and mine acts just like yours, perfectly normal. mine has been running good now for a few years acting the same way. When you return the throtle back to idle it starts to spray again.
  #7
Old June 27th, 2007, 12:30 PM
Thanks for all the replies fairly new to older outboards Just had one more question on were the lower exhaust port is the prop is a sealed shaft with the pickup screen and tube just above the prop no bigger holes were it look like exhaust would come out just small holes thanks
  #8
Old June 27th, 2007, 01:03 PM
F_R F_R is offline
The snout sticking down aft of the propeller is the exhaust outlet. The water intake screen is on the leading edge of it, exhaust comes out the big hole to the rear.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help with carb and synch - 1959 35hp Lark deserttoad Johnson & Evinrude Outboards 5 May 8th, 2006 07:25 PM
1959 35hp Evinrude Lark Jay410 Johnson & Evinrude Outboards 4 August 25th, 2005 07:01 AM
1959 Evinrude Lark Jay410 Johnson & Evinrude Outboards 3 August 18th, 2005 05:27 AM
74 evinrude lark 50 hp propeller question matrix29 Johnson & Evinrude Outboards 0 August 5th, 2005 01:46 PM
1959 evinrude lark 35hp. spark plugs number KGSQUIRREL1 Johnson & Evinrude Outboards 3 November 14th, 2004 08:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
