Re: excessive smoke from 60 HP Mercury outboard
Well, Three's aren't exactly known for smooth idle! That being said, if you haven't taken the motor out on the water and run it, the fogging oil may have not yet burnt out of the motor. It's also possible to have an oil-fouled plug so you might want to pull them and check/clean/replace as necessary.
When you take the boat out, add a carbon-cleaning additive to the fuel, such as Seafoam (if you can get it); Chevron Techron; OMC Carbon-Guard; Yamaha Ring-Free (I forget what Merc's additive is called but they have one too!).
This'll clean any deposits out of your motor's innards and may make it smoke a bit less.
Note that if the fuel/oil mix is old it may smoke more; use a quality TCW-3 rated mfr's oil or something like Penzoil Synthetic Blend (Wal-Mart has good prices on gallon jugs of the stuff). A full-synthetic oil will typically smoke less than Dino oils. If you can get non-alcolhol fuels, use them.
If you still think it's smoking excessively after getting it out on the water, you may have an overly rich idle mixture adjustment (you'll need to tweak the idle needles with motor warm and in gear). Or carb issues. But first try the additives and see how that goes.
HTH............ed
