  #1
Old June 27th, 2007, 01:13 AM
byrdman64 byrdman64 is offline
Default 1989 evinrude 175xp will not going above 2000 rpms
Just replaced fuel, filter, fuel lines, had compression tested-ok spark plugs fine.
water pump is ok
starts fine, idle's fine, shows 5 psi water pressure with boot on at idle
revs to above 5000 rpm, with boot on and in gear will rev to above 5000 rpm.
put the sucker in the water and will not go above 1500 to 2000 rpm.
what the heck is wrong?
  #2
Old June 27th, 2007, 01:19 AM
ob ob is offline
Default Re: 1989 evinrude 175xp will not going above 2000 rpms
I'm going to guess that your carburetors are fouled and need dismantling and cleaning .Wouldn't hurt to install new kits.Otherwise,running on the hose and reving without load is no indication of how it will perform under load in water with back pressure on the exhaust.Also ,never rev that engine above 2500 rpm on the hose.
You could have helped determine whether a restricted carb/s is the culprit by performing a couple of things while test runnning in water.Once the engine reaches the point at which it will no longer accelerate,you could have bumped repeatedly on the key primer to see if it would respond.If so,then a fouled carb/s is likely the problem.If not,you could have next tried repeatedly pumping the fuel primer bulb and see if it would respond.If so ,then a fuel pump or fuel delivery to carb/s problem exists.
  #3
Old June 27th, 2007, 01:32 AM
the boat has set up for 1 to 3 years not sure the guy I bought it from wife has cancer and he only started it once a month i think. he had sta-bil in the tank when i got it and I change the fuel out the day i bought it.
sounds like your right, a mechanic pulled the bowl screws and said the bowls were clean but i Guess that doent mean a thing huh?
Thanks for the reply
  #4
Old June 27th, 2007, 01:39 AM
ob ob is offline
Your not going to be able to tell much by just draining the carb bowls.I lean even harder towards fouled carbs now that I know the engine has set out of use for several years.Very common problem with two stroke outboards.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 evinrude 225 wot rpms/prop cornholio Johnson & Evinrude Outboards 6 October 21st, 2005 09:37 AM
93 200 txrr wont rev over 2000 rpms dpfishndoc Yamaha & Suzuki Outboards 7 May 23rd, 2005 04:45 PM
70 hp Evinrude bogging out at 2000 rpms sjames Johnson & Evinrude Outboards 4 August 16th, 2004 10:22 AM
1986 evinrude 175XP jaxbroker Johnson & Evinrude Outboards 1 January 3rd, 2004 07:51 PM
93' 175 mercury will not go over 2000 rpms? ranman Mercury & Mariner Outboards 1 July 2nd, 2003 03:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
