Thank you foaks for the info - this afternoon i went to the shop with the old champion plug (L75V) and indeed they recommended the equivalent of NGK: BUZHW. I just wanted to be sure the right plugs were installed in the first place.
Quote:
Originally Posted by Silvertip
Be aware that if you decarbon your engine at home, do it on a surface that you are not especially proud of as it makes a dreadful mess. You might also notify your local fire brigade (and your neighbors) before you do this or they may think your home is on fire.
Lol - i did hear those before yes - while reading the forum i stumbled on other posts describing the "decarbing". Actually i scraped carefull in a cylinder and it was not that bad what came out, but I can imagine there is some goo here and there - seen the spark plug. So I'm considering the procedure - i just need to have a waterhose-adapter before i start it.
The firebridage is at the end of the street ha ha lets' see if they are alert
As stated above: model year is 1985.
I dont know if the engine has been still for a long time - at least there is cooling water enough - so appearantly the impellor still is half-decent.
