My short shaft 20 tiller steering is "wiggly" .
The whole engine moves quite a bit on the transom mount frame and all I see stopping it is a series of rubbermounts (the parts book calls them), 3 down low and 3 up high.
Probably wouldn't be noticeable on a V hull boat, but on my inflatable it makes it real quirky at high speeds.
I took the 2 "shell" parts off down by the vent plate along the exh hsg, to look at the 1 mount and 2 bumpers in there. They all look like new. I see no way to tighten them.
I was thinking I could make some stiffer ones out of polyurethane but I don't see how those 2 side ones even attach - are they glued? cant be....the parts book shows a gasket? but no bolts or fasteners of any kind - the 2 must screw together I'm thinking....
The 3 mounts up under the pan look "as new" too.
They're all the 1975 original parts, but this motor has real low hours - spent most of it's life in the basement.
Did my mounts go soft? Or is this wiggling normal?
I gotta stiffen it up somehow. It's scary. It feels like your going to get into a speed wobble with the boat.
