1995, 4.3 Mercruiser LX, Serial # OF421280
Idle is 1200 RPM on muffs. Owner's Manual says idle should be 650-700 RPM IN GEAR.
On muffs, I have tried to set the idle back using the adjusting screwl. What I noticed is that there seems to be "play" in the linkage. (Throttle cable seems OK, but the play in the linkage, between the cable, through to the linkage rods is just enough to keep the engine running at 1200 RPM.
All I have to do is press lightly on the linkage, and the linkage moves against the set screw, and the idle drops to 700 RPM. I have tried lubricating all the hinge points in the linkage, but no change yet. Nothing seems to be binding.
Questions:
1) Anything else I can adjust?
2) When I put the engine in water, in gear, still at idle speed, will the slack in the throttle cable and linkage disappear.
Thanks
Questions:
Thanks
