Evinrude 40 hp 1992 10 pole alternator. Original tach has died and replacing it with a Teleflex 61278. Problem: New tach not working. Set at 5p per instructions and checked AC voltage at the tach terminals. 9.8vac ( between send and ground terminal) at idle and voltage ramps up when increasing throttle. DC voltage is 12.5 between IGN & GRND. Tach needle drifts up to about 100 at rest (key off ) then goes to zero when ignition switch is turned on. Ran jumper wires from engine tach terminal to the tach itself and also ran ground jumper from negative of battery to the GND on the tach. AC voltage reading is the same as mentioned above and ramps up when throttle is advanced.
Wondering if new tach could be bad????
