  #1
Old June 25th, 2007, 11:35 PM
10ptbux 10ptbux is offline
Default Another Painting Aluminum Question
I have a 12' jon that I plan on repainting. I've read a lot of posts and am pretty much confused. I want the boat to be an OD green inside and out, nothing fancy. I had planned to pressure wash off all the paint I could, then remove the rest with the scotchbrite pads, then prime with a self-etching primer and then paint with Parker's Duck Boat paint. Will this work? Also I've read some stuff about preventing corrosion when replacing transom boards. Is using SS bolts enough? What's 5200 and I've also read to use grease? Does it matter what type of grease? Thanks, any help is appreciated.
  #2
Old June 25th, 2007, 11:42 PM
Gary H NC's Avatar
Gary H NC Gary H NC is offline
Default Re: Another Painting Aluminum Question
The paint should work fine with the etching primer.
The 5200 is a 3M adhesive sealant.
It is good to use on thru hull fittings and places below the water line.
If its anything that may need taking apart again use 3M 4200...its a little better to work with if things ever need taken back apart.
Its also a good idea to seal the transom wood with epoxy resin to water proof it..
__________________
1981 ChrisCraft 210 Scorpion K,175 Johnson SeaHorse
  #3
Old June 25th, 2007, 11:56 PM
Great, thanks for the help.
I had the boat in the water last weekend and very small amount of water seeped in and it appeared to come from the drain plug. The boat has sat for almost 17 years so the rubber was dried and cracked. Should I be concerned with using the 5200 or 4200? Will removing the old paint cause new leaks?
Good tip on sealing the transom wood, I'll be sure to do that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
one more aluminum painting question Puglily Boat Restoration and Building 2 November 5th, 2006 01:09 PM
Aluminum Painting newf1 Boat Restoration and Building 3 March 30th, 2005 05:13 AM
Painting aluminum rick3b Boat Restoration and Building 3 February 7th, 2005 03:52 PM
Painting aluminum shipoffools Boat Topics and Questions (not engine topics) 1 February 27th, 2004 09:13 PM
painting aluminum rub rail???? customcar2boat Boat Topics and Questions (not engine topics) 3 June 9th, 2003 11:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
