  #1
Old June 25th, 2007, 11:05 PM
raven45227 raven45227 is offline
Default evinrude 48 spl idling problem
my uncle has a 48 spl outboard that will not idle. we took the carbs off and had them cleaned and put them back on only to do the same thing. what could be causing this problem? it runs fine every other way. any help is greatly appreciated. how good are these motors and are there any problems with these motors?? thanks in advance Raven
  #2
Old June 26th, 2007, 11:56 AM
fireman57 fireman57 is offline
Default Re: evinrude 48 spl idling problem
There is nothing wrong with those engines. Did you clean them yourself or have a dealer do them. I would put new kits in them if I had them apart. Make sure that you give them a good soak and every jet and passageway is blown out with air.
  #3
Old June 26th, 2007, 12:02 PM
redtech redtech is offline
outboard carbs are coated so just spray with carb cleaner NO SOAKING this something you do on cars not boats
check synk and lynk, best to have Q series champions and the go after carbs
  #4
Old June 26th, 2007, 01:35 PM
Silvertip Silvertip is offline
Check for spark on both cylinders and check compression. An engine with a dead or very weak cylinder will not idle well -- especially a two cylinder. Have you adjusted the idle speed and idle mixture with the engine in the lake (not on muffs). The dealer can't do this for you if all he had is the carbs.
  #5
Old July 19th, 2009, 08:10 PM
nfd550 nfd550 is offline
hey can anyone tell me where the idle adjust screw would be on a 48spl i think late 80s motor?? im having problems with the engine idling it keeps stalling also it stalls when i put it into gear i think the idle is way to low ??? thank you david LI,NY
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
77 55 EVINRUDE IDLING PROBLEM praetor Johnson & Evinrude Outboards 27 September 23rd, 2006 07:14 PM
1990 25HP Evinrude idling problem steve694 Johnson & Evinrude Outboards 1 August 3rd, 2006 02:55 PM
1958 Evinrude starting/idling problem ironmachineus Johnson & Evinrude Outboards 5 June 1st, 2006 08:32 AM
another idling problem avago Johnson & Evinrude Outboards 4 July 5th, 2004 11:15 PM
Idling problem Evinrude 7-1/2 hp Fleetwin outboard motor shurvell Johnson & Evinrude Outboards 1 July 16th, 2003 09:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
