  #1
Old June 25th, 2007, 10:08 PM
fishmonger.33 fishmonger.33 is offline
Default mercury lower unit
i have a mid to late 70's merc, and am looking at buying one for cheap, it is ok to simply switch lower units on these motors? i mean does everything fit the same, it is the same hp. both 50hp 4 cly. except one has pw trim and one doesnt.
thanks
fishmonger33
  #2
Old June 26th, 2007, 02:03 AM
gejandsons gejandsons is offline
Default Re: mercury lower unit
Yes the parts are interchangeable on like motors. Power trim is an option.
  #3
Old June 26th, 2007, 11:28 AM
Chris1956 Chris1956 is offline
Cool Re: mercury lower unit
Fish, If you are simply planning to move the Power Trim, it is far easier to remove/reinstall the PTT brackets, rather than pull the powerhead and lower unit and switch midsections.
  #4
Old June 26th, 2007, 03:48 PM
ok, heres my situation, i have my original motor, which i overhauled the lower unit on, but the uper shift shaft in the motor snapped becuase it rusted through, and to take apart the whole motor to get at this shaft out is alot of work i dont have time for. plus the part has been discontinued. and im interested in picking up an almost identical motor for cheap. so i want to take my overhauled lower unit, and put it on the new motor i am planing on buying (the one with the power trim) because this one i am buying needs a new water pump impeller, so i can put on my fixed up lower unit on this motor with pt, and keep my old motor and the loer end from the one im buying for parts. so i was just curious if anything would be affected by the switch of lower units
thanks again
fishmonger
  #5
Old June 26th, 2007, 05:27 PM
Wink Re: mercury lower unit
If the only difference in the motors is that one has PT and the other one doesn't, then the Lower units should be identical. You will want to remove the reverse lock rod on the manual tilt model, since you will no longer need it.
  #6
Old June 26th, 2007, 05:50 PM
thanks, will do, i am going to look at it shortly, i hope it is in better shape then mine, ive been so anxious to get out on the water this year! its driving me crazy, ans just another quick question, by hooking up a batery to the motor, can i test the pw trim?
thanks again
fishmonger
  #7
Old June 27th, 2007, 11:37 AM
Fish, The PTT units should have seperate battery cables, from the motor.
  #8
Old June 27th, 2007, 05:51 PM
bad news, the guy i was going to buy it off was a complete idiot, it did not have power trim, plus he sold it like half an hour b4 i got there
another one will come up =D
thanks
fishmonger
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 35 Lower Unit :( Maintain Mercury & Mariner Outboards 8 July 14th, 2008 10:35 PM
94 115 mercury lower unit help zrtman Mercury & Mariner Outboards 3 August 11th, 2006 06:57 PM
Finding match between 25 Mercury upper unit and its lower unit Safari89 Mercury & Mariner Outboards 2 July 10th, 2006 11:21 PM
Mercury Lower Unit phinfan Boat Topics and Questions (not engine topics) 2 March 14th, 2006 05:35 PM
Lower Unit for Mercury 850 Rakman Mercury & Mariner Outboards 3 June 7th, 2004 08:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
