freddyray21
- Jun 10, 2006
- 2,460
Some of you may have seen my recent threads on the rubber smell I have been smelling. changed the impeller and it didn't fix the problem. So took it to the shop and they said I needed to change the housing and everything since it was fried. Okay I will give them that as I screwed up once and forgot to turn the water on adjusting the carbs, but I still can figure out how I would be able to smell that. It is inside the lower unit and seemingly no way for it to get out. They tell me the bellows are in good shape. Through the shift shaft?
