marty5030
- Aug 9, 2006
- 31
So after a good day of fishing in my 1990 Champion w/ 150 hp Evinrude (1990 too), I get home and go to take the motor totor off. The motor tilts up ok, and then when I go to tilt down nothing. No click, no noise, zero. I press the tilt up and it goes just fine, down again, nothing. I also tried the control on the throttle and same thing. So I go inside to research on iboats, learn a little about relays and go outside to test with the multimeter (I have power to both up and down). Then try it one more time and al of a sudden it works just fine. So my question is how do I test relays or might it be worse then that (had boat fully serviced 2 months ago)
Thanks in advance,
Marty
Thanks in advance,
Marty
