reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I looked at a pretty neat looking boat today, it's an early to mid 60's era trihull, made by AeroCraft. The hull is not a very pronounced trihull and more resembles the more modern style hulls.
The floor has a few soft spots but the transom is solid, the floor looks like it only spans the forward section of the hull and that the rear of the deck is actually the bottom of the boat? The bilge forms right at the back of the floor. The soft area is actually under the dash area between the two hull humps formed by the trihull design.
Has anyone had one of these apart? I'd be interested to see how these are built.
The transom appears not to have any wood, or at least none that's glassed in. The only wood I see is what looks to be a 2x6 which is glued up into the top of the transom where the outboard clamps are. The rest apears to be only plain fiberglass. The hull is 17' long, with a 6' beam and weighs only about 700 lbs or so. I can lift the boat from the side off the trailer fairly easily.
The floor is also pretty thin, it's only about 3/4" thick at the rear, and there's no sign of any stringers leading from the transom?
I can reach around the gunwales and feel both sides of the floor, so what ever they used, it's less than an inch thick.
It's got an early 50hp Chrysler on it now that runs but needs some work on the fuel system, someone has bypassed the fuel pump and is running it direct to the tank, (no pump and it runs???) I like the open floor design of this boat, super light and very simple.
Any pro or cons on these in particular? I realize that the Chrysler motor is a drawback, but it's clean and runs good as is with excellent compression, (124lbs on each cyl.). It actually started by accident on me while just turning the flywheel, so it cant be in too bad of shape. (There's no key, just a starter button and a kill button, so I guess these were magneto motors?)
The closest pic I can find online is at Fiberglassics.com under AeroCraft Maverick. This one is older and a bit longer, but looks to be about the same boat.
From my first impression this looks to be a very well built hull? The fit and finish is near perfect, this boat is in great shape having been garage kept all it's life, and looks to have seen little to no use.
My main concern is what am I in for as far as the floor, I've done several other fiberglass boats before, but this looks totally different to me, it's my guess that this only has a small section of plywood thats used more as a filler panel to flatten the floor up front, with the rest being solid glass. there's just not enough room to have stringers under the floor anyplace, and the outer hull is solid with no flex.The floor goes flat just behind the drivers seat and is solid there, it's the area between the trihulls that's soft, too soft to stand on. The floor is glassed over completely and the soft area feels like a rag, with only a support beam in the center about two feet long down the middle in the forword floor area. The area below the front bowrider area is solid and the under compartment is actually the outer hull, no subflooring.
