I have a 1988 bowrider with a 3.0 mercruiser in it with an aluminum 23 gallon gas tank. I had the tank out cleaning it and I went to dis-assemble the fuel pick-up tube check-ball fitting from the tube that drops into the tank because it seemed plugged ( I couldn't blow through it from either side ). I ended up snapping the fitting off where the check-ball screws into the tube.
I am in need of the pick-up tube that goes into the tank and new check-ball.
What I can't find is a place to buy another one.
Any advice would be appreciated.
Thanks....
Thanks....
