Hello Gents,
I am thinking about getting a Zodiac Mark IIC HD and a jet outboard for our shallow fast rivers in BC. I have tried a couple of aluminum boats 17'+ but found them to difficult to handle on my own, therefore a Zodiac would seem a better choice.
Mark IIC HD is rated for Max40HP and 209lb weight on the short transom. I would like to get a Yamaha outboard, and have two choices, a 4 cycle 40/28Hp jet that weighs 206 or 2cycle 50hp on which I can replace the leg with a jet pump bringing the power to 35 at the jet for a total weight of 190lb. The cost difference is appx.$500 more for the 50hp. Very difficult to find 2 cycle 40hp used and in good shape...
Which outboard would you choose and why?
The outboards are long shaft so I would have to raise the transom, correct? That will not affect the performance, will it?
Most of our aluminum boats have a tunel for the jet pump, obviously that is not an option for the Zodiac, will I have problems with cavitation?
If there is anything to add pls. do so.
And for your help I will take you fishing for steelhead in the God's country-Terrace/Skeena
George
