  #1
Old June 24th, 2007, 02:18 PM
MN_PatS MN_PatS is offline
Thumbs down 115 HP Evinrude FICHT Inline Fuse Locations
I've installed a new Optima battery in my boat and it's been tested to verify it is at full charge. The connections are good but I get no activity what so ever when I use the power trim buttons either on the motor, on the throttle or in the front of the boat. When I turn the key, there is no sound whatsoever which makes it seem like there is a short somewhere. I called my local Evinrude Dealer and they think that I just popped a fuse. The problem is I'm not sure where the fuses are located. I'm assuming that they are in-line fuses somewhere under the cowling but can someone help me figure out where to look? It is a 1999 model year FICHT I believe.
Problem Solved
__________________
MN_PatS
Last edited by MN_PatS : June 26th, 2007 at 12:42 AM. Reason: Problem Solved...Delete the thread to free up space
  #2
Old June 24th, 2007, 02:44 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 115 HP Evinrude FICHT Inline Fuse Locations
Im no expert but im working on the same problems myself right now and Ill share what ive found. theres a 20 amp fuse right beside the starter in a rubber grommet. theres also a 2 amp fuse in the relay box near the battery, it will have a plastic cover that screws down closed. I too just bought a boat and found both these fuses to be cracked. If you find any more please let me know since i too am trying to start my boat. Hope i helped, and gl
  #3
Old June 24th, 2007, 03:35 PM
Maybe the nature of the fuse I'm looking for is different from my expectation that it would look like an in-line auto fuse. When I look near the starter motor, I see the wiring harness and connectors but I'm not seeing any fuses that I can replace. If I'm looking at the motor from inside the boat, the starter is to the right side of the engine.
__________________
MN_PatS
  #4
Old June 24th, 2007, 03:43 PM
HighTrim's Avatar
you wont be able to see the fuse, its concealed in a black rubber grommet. Look to the right side of the starter, there will be 2 black lines running to a black rubber connection, open that up and inside it will be the fuse, prob a 20 amp. the rubber grommet will probably been held secure to the motor by a metal clip or holder of some kind, gl
  #5
Old June 24th, 2007, 08:37 PM
seahorse5 seahorse5 is offline
Quote:
Originally Posted by MN_PatS View Post
Maybe the nature of the fuse I'm looking for is different from my expectation that it would look like an in-line auto fuse. .
HighTrim is mistaken as he is describing the fuse that is used in a carbureted outboard. You have a FICHT motor which is a completely different animal.
Your fuses are in the Power Distribution Panel on the starboard side of the motor. It is a black plastic cover that has two silver screws holding it on. You can use a dime to loosen the screws. There are 7 mini-blade fuses in there, all 10 amp.
  #6
Old June 24th, 2007, 10:48 PM
Smile Re: 115 HP Evinrude FICHT Inline Fuse Locations
Thanks, that's exactly the help I needed
__________________
MN_PatS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 225hp evinrude ficht fuse #1 doug brander Johnson & Evinrude Outboards 0 August 23rd, 2006 06:35 PM
evinrude 115 20 amp fuse blows michael115 Johnson & Evinrude Outboards 2 May 5th, 2006 03:03 PM
1973 65hp Evinrude key switch wire locations aggierud Johnson & Evinrude Outboards 7 September 16th, 2005 08:59 PM
Inline fuses and Fuse Block? olmpilot Electrics, Electronics and Trolling Motors 11 August 30th, 2004 04:20 PM
evinrude 60 heat and oil sensor locations kyfisherman Johnson & Evinrude Outboards 1 June 7th, 2004 11:35 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
