had the boat out for the first time this season. let motor idle up to temp had good oil pressure, started across lake at about 2000 rpm motor ran fine for about five min. then shut down abruptly. starter is not able to turn engine over but it does rotate slightly. maybe a 2" stroke path. what do ya think my worse case scenero, broken rod or cylinder freeze and is probably replace the engine or do you think its reparible. no water in oil. no holes in block.
