  #1
Old June 24th, 2007, 12:18 PM
jvcoconut's Avatar
jvcoconut jvcoconut is offline
Default PORPOISING 232 Deckboat Somebody HELP?
Hi,
I own a 2005 232 Sunesta 5.0 gxi with a duoprop outdrive and double bimini from bow to stern. I notice when I look at some (not all) deckboats cruising next to me at all speeds, they ride smooth and nice, NO SLAMMING, NO PORPOISING.
I have tried everything.....Full Boat, empty boat, no bimini, both biminis, ice chest, no ice chest...I cannot get it to stop porpoising (even on semi glassy water). I currently trim the outdrive to just before the first line on the trim gauge and have tried all other settings below that and it still wants to porpoise. The only way I get it to stop is to back the throttle off momentarily and re-engage the throttle, then it smooths out for a bit.
WHY CAN"T MY BOAT RIDE LIKE OTHER SIMILIAR DECKBOATS????? The hull is deep enough and the boat is heavy enough, it should cut through chop smoothly and not porpoise on jetski wakes....RIGHT? I talked to my service guy @ Sun Country Marine in Onatario Ca and he rifled off several questions to make sure I was doing everything correctly in the operation of my boat, which he confirmed I was. I asked about trim tabs. He has some customers that installed trim tabs and it took away all porpoising. He also said they don't sit on the boat all that great due to the large swim step, but they can be made to function properly.
I purchased the boat because Chapparal claims to have the "best hull design years running" I think it is a crock of sh*t. I am happy with the boat, except for the ride.
Are trim tabs my answer?
Anyone experience the same problems and fix it with trim tabs?
Which ones will fit under my huge swim step?
Any answers would be appreciated
  #2
Old April 1st, 2008, 01:04 PM
Thept Thept is offline
Default Re: PORPOISING 232 Deckboat Somebody HELP?
Hi, did you ever get this figured out? I ask because I am looking at a sunesta deck boat or the bow rider....both Chaparral....and don't want the same problems. I have heard that the sunesta's will ride over the wave instead of chop through it but it can be awfully rough if you get a 3' swell or bigger. I don't want it to be slamming all the time
Thanks'
  #3
Old May 25th, 2008, 07:55 PM
sevierd sevierd is offline
Howdy,
I've got an 04' 232 and I don't have any problem with porpoising. Now I've got an SX drive instead of DP but I'm not sure if that could be related. One thing I have noticed is that the trim range is very small. There doesn't seem to be a huge difference between full down and being too high where it does start to porpoise (on a side note, just before it starts to porpoise I get a drop in mph so as I understand it, it's getting too high anyway). On my Faria analog trim guage when I'm running at WOT, I'll have it trimmed up maybe a quarter inch max (and that's probably overestimated) from full down. I put nauticus smart-tab trim tabs on it to help it get up on plane faster and ride a little better and it does make the boat get up and out faster but I haven't noticed a change in the trim range or way it will porpoise at higher speeds and too much up trim. Also, they were a breeze to install with no problems with the swim step. They do tend to put up some spray behind the boat though so you get some water in the face when tubing on a shorter line. All in all I've been very happy with the boat which FYI, I get about 45 mph at WOT on smooth water. Could get more with a different prop but I want the low end grunt more than the top end. I'd love to hear if you find a solution/fix to your problem.
  #4
Old June 4th, 2008, 07:04 PM
12vMan's Avatar
12vMan 12vMan is offline
I own an '04 252. I'm new to the site, and don't know if you ever figured out the porpoising problem.
A planing boat that has excessive weight at the transom will tend to porpoise. Underway the excess transom weight makes the boat go down by the transom, but then forward speed overcomes the weight and the bow drops, most often slamming down. This condition repeats itself time and again. The boat is simply out of balance.
The cure is to remove weight from the transom. Shift any movable weight forward, especially passengers if sitting near the transom.
The porpoising may also be caused by a problem they had with their thumb trim switch. It would short inside and continue to trim up, which would cause the boat to eventually porpoise.
  #5
Old June 13th, 2008, 03:51 PM
suzhol76's Avatar
suzhol76 suzhol76 is offline
We had the same problem with our 87 Chaparral we bought a hydrafoil at Bass Pro shops for 50.00 it makes a huge difference in the driving and riding of our boat!
__________________
Suz
  #6
Old June 17th, 2008, 03:54 PM
kmhattrk kmhattrk is offline
I had similar problem on my 22' Mariah Deckboat. My solution was to add the SX series Smart Tabs. These have basically erradicated this problem even in very choppy or busy ICW conditions. Besides correcting this problem, they also kill slow speed wander and DO get me on plane quicker. It is a very good fix at not a whole lot of money.
  #7
Old September 25th, 2009, 11:17 PM
steddy steddy is offline
I know this thread is getting a bit on the old side, but I thought I might bump it up. I have the same problem with the porpoising on my 178 XL BR Chappey 3.0 Merc I/O. I bought a Sting Ray Hydrofoil with the hopes of the porpoising ending. Not the case, but that sure did help with planing, throttle response, and handling. I find that by trimming down for just a second or two, while it shaves off a few MPH briefly, eliminates the porpoising immediately. After a few more seconds, I trim back out and continue on my way. I repeat these steps every 10-15 seconds as the boat repeats its porpoising cycle. Annoying, yes.
We just bought a 1991 Thompson 205 Carrara, with the 4.3 Merc I/O, and it does about the same thing. It has the cuddy opposed to the open bow, and weighs probably twice as much.It has some cheapie rigid mount fixed trim tabs on it, but I don't know if they really help. Again, I just repeat the process with the trim down then back up.
Neither boat will porpoise unless the trim is nearly all the way up. Also, the faster I go, the less they porpoise. At full throttle, neither one does it hardly at all, even trimmed all the way out in a mild chop.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Deckboat Restoration rbarnesjr Boat Restoration and Building 3 February 2nd, 2006 04:46 AM
DECKBOAT BASICS 12153dad Boat Topics and Questions (not engine topics) 2 September 13th, 2002 10:52 AM
CONSIDERING DECKBOAT New2Boats Boat Topics and Questions (not engine topics) 3 September 6th, 2002 09:03 PM
NEED DECKBOAT ADVICE..... BillT111 Boat Topics and Questions (not engine topics) 6 December 19th, 2001 04:56 AM
Need Deckboat advice Mary Bucklew Boat Topics and Questions (not engine topics) 2 November 13th, 2001 10:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
