  #1
Old June 24th, 2007, 06:48 AM
wilber wilber is offline
Default 1994 88 evinrude blowing smoke
Help, I just bought a smoker craft with a 94 88 evinrude that was running rough a slow speeds, so I was advised to use sea foam, now it is smoking bad the longer I run it. Also having probems with trim, tilt works but no trim. I think I got the shaft on this one...
  #2
Old June 24th, 2007, 08:41 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: 1994 88 evinrude blowing smoke
Welcome to iboats.
Don't be too concerned about the smoke just yet. It might do that as the motor cleans itself. It is more likely to be due to the kind of oil used than anything else. Different brands smoke more or less.
Describe more about the trim problem.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old June 24th, 2007, 10:42 AM
clint clint is offline
Cool 1994 88 evinrude blowing smoke
Let the sea foam do it's job. They extra smoke is the burning off of the extra oil and stuff accumulated thru the past years on the cylinder walls. You shouls rebuild those carbs after running the smoke out and install new spark plugs. Good Luck!
Clint =)
  #4
Old June 26th, 2007, 07:42 PM
thanks, the tilt goes allthe way down when i give it the gas and wont trim up until i slow way down..is there more than 1 relay?
  #5
Old June 27th, 2007, 01:25 PM
Quote:
Originally Posted by WillyBWright View Post
Welcome to iboats.
the tilt works fine but when give it the gas the motor goes down and won,t trim up until i slow down..I checked the fluid level, it's ok...
  #6
Old July 18th, 2008, 04:53 PM
bigwilly bigwilly is offline
my boat did the same thing more than likely u have a bad o-ring in ur cylinder hopefully u can take it and have it repaired the o-rings for mine were obsolete so i ended up buying a new jack plate with tilt and trim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Johnson 130 1995 Blowing oil/smoke southshore Johnson & Evinrude Outboards 2 May 22nd, 2007 08:20 PM
I'm blowing brown smoke from my truck brother chris Non-Boating Technical Topics 7 December 28th, 2006 12:59 PM
1972 Johnson 9.5 blowing blue smoke jon1234 Johnson & Evinrude Outboards 4 July 7th, 2005 07:10 PM
1994 Evinrude 175 Excess Smoke/Oil Use DavidRT2T Johnson & Evinrude Outboards 10 October 26th, 2003 12:47 PM
New Merc 7.4 MPI blowing smoke/steam geoffandjackie Mercury & Mariner Outboards 4 August 29th, 2001 09:56 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
