  #1
Old June 22nd, 2007, 08:07 PM
bwatters bwatters is offline
Unhappy 1986 Mariner 60hp burned piston no. 1
I bought an 86 boat/motor combination with the motor not working. I took it apart and found number 1 piston and number 2 piston badly melted. I bored it out .030 and installed 3 new piston/rings. The water pump looked fine but I replaced the impellor anyway. I took the carbs apart and all jets looked squeeky clean. Put it all back together and it ran poorly (would not accelerate past half throttle. Third test drive it ran full tilt for 3 min. then quit. When I restarted it it knocked badly. Long story short, I have melted piston number 1 again!! My gas/oil mixture was 25:1. The only thing I can think of is that it is running lean on the top carb - possibly fuel pump problem - I changed the diaphram when I rebuilt it. Has anyone experienced this problem before with the 3 cylinder/2 carb models?
  #2
Old June 22nd, 2007, 08:58 PM
jebeebe jebeebe is offline
Default Re: 1986 Mariner 60hp burned piston no. 1
thats the one that usualy goes. My 60 merc did it. I don't know what caused it because I didn't own it at the time. I know a lean carb can do it. Excuse my typing, I have my arm in a sling from rotator surgery. I rebuilt mine and it runs good now, but I tore the carbs down and soaked them over night. I figured the water didn't get all the way through but like I said I don't know.
  #3
Old June 23rd, 2007, 03:04 AM
emckelvy emckelvy is offline
What was the maximum spark advance set to? You can easily 'smoke' a piston if the spark advance is set above 21 deg BTDC. And I'm also wondering if there's an ignition problem which is causing detonation.
What kind of fuel are you running? If you have non-alcohol fuel, you might try running premium in it.
You might try, at least during break-in, installing main jets one size larger, this may give you an extra margin of safety and you probably won't burn a piston next time.
Are the jets currently installed appropriate for your elevation? For example, if smaller jets were installed to run at higher elevations, they'd be way lean at sea level.
Probably didn't help to run the poor thing full tilt for 3 minutes straight with it being hardly broke in! That's an awful long time to run full throttle anyway, until the motor's been run for at least 20 hours. You're only supposed to use occasional bursts of full throttle up to around 10 hours and then just short periods between 10 and 20 hours.
Can't recall if this 3-cyl carried a thermostat, I'd definitely check that out if it did. Check the poppet too. Curious how warm it was running during the "burn-in". If the exhaust manifold was very hot, that's way too warm.
If your Wide Open Throttle (W.O.T.) with a lightly-loaded boat is too low (e.g., prop pitch too large), the motor can't spin up to its rated rpm and this puts great strain on the innards to the point of burning up pistons. Hopefully you have a tach and can tell what she's running.
The last suggestion I'd make is to do the mod where you relocate the 'telltale' from the side to the top of the block. This ensures that no 'steam pockets' or hot spots can develop, since the block will be fully flooded. You'll have to remove the cyl block water jacket cover to find the right location for drilling/tapping for a 1/8" NPT fitting.
HTH...........ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Mercury 60HP Burnt Piston - What Caused it? imported_Andy_P Mercury & Mariner Outboards 5 September 4th, 2006 10:50 PM
1986 Mariner 60hp not going into gear wgp Mercury & Mariner Outboards 1 July 4th, 2004 01:01 PM
Burned Piston dcracn24 Non-Repair Outboard Discussions 4 May 24th, 2003 08:42 AM
1986 Mariner 60HP Outboard texacana Mercury & Mariner Outboards 2 October 22nd, 2001 07:16 PM
Burned Piston KingJB Mercury & Mariner Outboards 2 May 10th, 2001 09:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
