Whats the break-in procedure for a rebuilt drive?
Zim
The upper half of my alpha I has been rebuilt, and it came with a tag that told me how to break it in... but throughout the past few months that has been mis-placed. I know it said it needed a 10 hour break in period, and not to run it at WOT for extended time, as well as not running it at any particular RPM for an extended amount of time. I think it said short WOT bursts were ok, but Im not sure. Can someone shed some light on that for me?
fendersfender
Re: Whats the break-in procedure for a rebuilt drive?
not positve, but dont beat the crap out of it, and change the gearlube after breakin period....my old manual says 20 hours, maybe yours is only 10....
Ayuh,........ you've got the Jist of it,........
It's all about the 10hrs(or 20hrs) Oil Change,.......
If there's No Big Chunks,......... you're usually Good to Go..........
frayed knot
The break-in procedure for an SEI drive is:
first 5 hours drive around slowly, building rpms up to 3500 at the 5 hr mark, put into reverse at least 10 times (probably not a big deal for an upper though)
5-10 hrs brief full throttle runs
10-20 hours normal operation, oil change before 20 hrs.
