Re: Mercury XR6 Water Pressure?
The only water available for the pee stream is what goes through the thermostats. Before the engine warms up, that is only 2 pinholes designed to let the air pocket escape from the top of the heads. At idle, much cooling water flows through other passages, so it does not get real hot, and the thermostats will open slightly, if at all.
If you get a real strong pee stream at idle something's wrong.
If you get a pee stream immediately on a cold engine, something's wrong.
Even at WOT, if in cold water, you might get a weak pee stream. That's normal.
hope it helps
John
