  #1
Old June 20th, 2007, 03:44 AM
erikgreen's Avatar
erikgreen erikgreen is offline
Default New boat, chevy engine
Hi again all;
As I mentioned in another thread, I just got a new boat for cheap... it's a 21 foot sea ray about the same design as my old one (SRV220), just no hard top. It's also 10 years newer, and comes with a 305 chevy engine instead of a 302 ford like the old one. It's labeled "Mercruiser 228". For those reading the old thread, I had bad info on which engine was included.
I have to fix the engine (milky oil, hence the low price) but if worst comes to worst I think I can swap out the chevy and put in a ford, provided I put in everything from the motor mounts back to the engine coupler, and I think I need to switch controls too.
On the outside chance I can get the 305 fixed, does anyone have any general comments on it? Like, is it hard to get parts, is this a lousy engine in general, or is it a keeper?
Your thoughts appreciated... I'm hoping not to get into a quagmire with this boat like I did on the other one (I replaced the transom, stringers, and everything else but the hull before giving up).
Erik
  #2
Old June 20th, 2007, 07:30 AM
imported_John_S imported_John_S is offline
Default Re: New boat, chevy engine
If the 305 is toast, go with 350 in that size boat. Not worth rebuilding the 305 or installing a 302.
  #3
Old June 20th, 2007, 11:03 AM
mtnrat mtnrat is offline
The only easy solution is to get a longblock 350 and swap all the parts from the 305. Make sure the longblock is from a similar year so everything swaps.
  #4
Old June 20th, 2007, 11:09 AM
erikgreen's Avatar
Okay. Is the longblock 350 the same size?
The reason I was thinking 302 is that I already have a running 302 from my other boat, pulled, on blocks in my garage.
  #5
Old June 20th, 2007, 11:27 AM
fourwinnsdook fourwinnsdook is offline
Find a ford guy and swap him the 302 for a 350. The 305 is the same block as the 350. everything should swap over as long as it's around the same year. the 305 chevy engine is a dog compared to the 350. What is wrong with the 305? if it's an easy fix, fix it and sell them both to get a good 350. You wouldn't be sorry and parts would be a dime a dozen.
  #6
Old June 20th, 2007, 11:33 AM
Windykid's Avatar
Windykid Windykid is offline
Harmonic balacer will have to be changed to a 350 balancer.
  #7
Old June 20th, 2007, 11:47 AM
erikgreen's Avatar
I have yet to do work on the 305, but it may be nothing wrong or it may be a cracked block. When it was de-winterized this year the oil was milky. If it can be fixed cheaply I'll fix it and use it for a year, but if not I'll probably go with a 350 long block, maybe with vortec heads.
Anything besides the balancer that would need to be new, besides the usual "long block" parts?
  #8
Old June 20th, 2007, 12:04 PM
Haut Medoc's Avatar
Haut Medoc Haut Medoc is offline
Forget using the 302 in there.....
There are too many modifications to make it work to be cost effective.....
I agree with the 350 repower, just make sure it is the right vintage....
__________________
Disclaimer!: In my inexpert opinion......
  #9
Old June 20th, 2007, 12:48 PM
erikgreen's Avatar
It looks like I might need to sell the 302 then. Should I keep the 888 outdrive, which also works, as a spare or would that need significant mods too? If I can sell both, I'm partway to having a long block if I need it.
  #10
Old June 20th, 2007, 12:54 PM
Haut Medoc's Avatar
The drive will work just fine as a spare......
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
454 Chevy Engine Bassy Non-Boating Technical Topics 22 January 25th, 2007 03:10 AM
wiring on a 350 chevy engine jetboat1031 Electrics, Electronics and Trolling Motors 2 November 18th, 2004 12:13 AM
Chevy 350 Engine skicat Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 March 31st, 2004 03:49 PM
chevy v6 engine swap I970grancoupe Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 September 17th, 2003 08:48 PM
5.7 Chevy 350 water in engine oil jwvlaar Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 July 22nd, 2003 09:01 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
