  #1
Old June 19th, 2007, 05:08 PM
alphainfinity alphainfinity is offline
Default 2001 SeaRay 180BR---19 pitch prop
Hi all,
I will be a new boat owner as of tommorow. I am purchasing a 2001 Sea Ray 180BR. The dealer stated that they would throw in a 19pitch prop for free and that the prop would assist in pulling tubers, skiiers etc etc. They said it is a much better prop than what comes standard on the boat. I am brand new to boats and I wanted to get some sound advice from other SeaRay owners. How will this prop affect performance? I probably won't spend alot of time towing folks around. Any prop suggestions, or for that matter, is there anything I should know about this boat from those who have owned one?
Thanks!
  #2
Old June 20th, 2007, 07:00 AM
mkfs9 mkfs9 is offline
Default Re: 2001 SeaRay 180BR---19 pitch prop
Need to know the engine size and hp.If it is the 3.0 ltr 135hp that would be ok for the average use.ie loaded boat/ski ect.A 21 pitch would be ok as long as your load was lighter.because you would have a slower pullaway(holeshot).
  #3
Old June 20th, 2007, 12:54 PM
I took the boat out for a test drive. I will be signing on the dotted line today. It looks like the 19 pitch prop limits my speed to about 35mph. I am fine with that because I am brand new to boating. If I have to keep the wheel at 2 oclock to keep the boat straight, is that a sign of a problem or is it more of an alignment issue?
THanks for the response!
  #4
Old June 21st, 2007, 07:57 AM
I would have thought you would get around 40 mph at least with the 19p.What revs were you pulling to acheive only 35mph.you need to get 4200-4500 revs when going flat out.(wot).As for the 2.oclock steering you can make adjustment with the anode just above the prop to help the boat run straight.
  #5
Old June 21st, 2007, 01:33 PM
I was pushing 4500 RPM's with the motor trimmed at about 35% up. There is a big FIN right above the prop that came with the boat. Should I take that off?
  #6
Old June 22nd, 2007, 05:50 AM
These large fins are to help the boat plane at a slower speed.If you dont need to do this take it off and compare any difference in performance. Your revs are ok so the prop is well suited to the boat.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Ladder For 1989 SeaRay 180BR ruffup Sea Ray Boats 3 March 31st, 2007 11:09 AM
The right pitch prop for 83 searay 260 john9480 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 October 12th, 2006 02:42 AM
Prop comparisons; straight pitch vs progressive pitch. pafoxhunter Johnson & Evinrude Outboards 1 June 11th, 2005 09:50 PM
SeaRay prop pitch Tom97Sundancer Boat Topics and Questions (not engine topics) 2 February 20th, 2004 06:35 AM
2001 Searay 260 sundancer ras737 Boat Topics and Questions (not engine topics) 2 April 15th, 2002 07:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
