Evinrude 40 hp 1986 - loss of power
Hi!
I´ve been reading this forum the last couple of days looking for a similar problem that I have, and found some clues to work with. But the threads stops before the problem is solved so its difficult to know which lead I should follow.
I have a 1986 european buildt (Belgium) Evinrude 40 hp that don´t work very good anymore.
It all started at the end of the last season when the engine began to misfire and loose power at medium and high speed. After a while I had problems to get it to plane - sometimes it did, sometimes not.
I´ve only had the engine for one season and it worked just fine untill this happened. I thought maybee it didn´t get enough fuel so I checked the fuelline from the gas tank to the carbs. To my surprise I found out that a previous owner had glued a large crack in the fuelpump-housing with epoxy glue. The glued part more or less fell off the rest of the fuelpump when I took it apart. I was satisfied when I thought I had found the problem and stored the engine i my garage for the winter.
A couple of weeks ago, I put in a new fuelpump, new sparkplugs, a new fueltank/fuel and fuelhose and bought a Seloc manual. Then I drove off to the sea to test the rig.
Nothing had changed. The engine startet and it sounded fine at idle, but was still misfiring at load. The strange thing is that it works better when I get it to plane, and I´m also able to keep it there. But it still misfires.
I went back home with the lot and cleaned the carbs with carbcleaner, blew all the jets with compressed air but nothing changed. Still the same problem.
No I started to suspect that the problem was something else than fuelproblems.
I made a compressiontest and both cyls gave 120 psi. I checked the spark and it looked good when I crancked the engine. I checked the coils for visible cracks and wear on the contactpoints. I found that the connecting point for the cable between the lower coil and a "black sealed box" at the left side of the engine was corroded. The point was actually reduced with 10-15 % compared to the other coil. I cleaned it, ensured that the cable had a good connection, but I have not tested the result yet.
So ladies and gents - before I tow the lot back to the sea for another test, is it anything else I can do/test? Do you think that a corroded contactpoint on one of the coils can produce this error?
Thanks a lot for a brilliant forum!
All the best from
Paul
